Need help with MRV | SatelliteGuys.US
Need help with MRV
directv newb
194
33
columbus, oh.
Hey, I have the genie, and now a h24 hooked up and running. I can't see the genie dvr recordings playlist on the h24. I have gone thru settings and it says MRV is active, ect.... I just don't see what I NEED TO DO to make the connection happen, any help?
you may not have the list set to show it. bring up the playlist of the h24, then press the yellow button, then select "filter by playlist", then select all.
you may not have the list set to show it. bring up the playlist of the h24, then press the yellow button, then select "filter by playlist", then select all.[/QUOTO]
When I go to menu-playlist on the h24 it says there are no recorded programs at this time, if I hit the yellow button nothing happens
ok, go to settings, whole home, status, then make sure it says authorized, and make sure it lists your network dvrs(whatever name you gave to them). the networked dvs should has "sharing on, deletion on"
OK OK OK - GOT IT. I called directv protection plan services and guess what, ALL h24-700 MUST get a software update to talk to the genie. I got the update and BOOM, it's all good.
Detroit Fan, THANK YOU VERY MUCH for your time and effort.
no problem, happy to hear it's working now
Direc Hr34 or Hr24
PS3 Hr34 Playlist
