Need help with missing channels | SatelliteGuys.US
ilfoman
105
North
I purchased a combo 118/119 DP LNBF and connected it to a SW21.
I get a good signal in the 50's on both sats, but many channels on 119 show the 015 loss of signal screen.
For example, 299 (Reelz) works, but 300 (hBO) does not.
I am subscribed to 250/HBO/Showtime/Starz and Cricket. The 118 channels work just fine.
The receiver is a 211k and I previously had it working perfectly on 61.5 and 118, but using Legacy Lnbf's. Could it be a bad LNBF?
Anyone know what my problem could be? I have performed multiple power resets and switch tests, but nothing works.
Thanks guys and gals.
Thanks Garys. that makes perfect sense. I've ordered a new switch.
So i'm guessing it's impossible to "mix" LNBF's - i.e. you can't have a Legacy and a DP connected to the same switch?
