Need help with HTL-HD.... | SatelliteGuys.US
  • Thread starter Thread starter jahan
  • Start date Start date
  • Replies Replies 0
  • Views Views 1K
jahan
29
I just installed the HTL-HD box and I'm having the following problems:
1. I can't remove the off air channels which appear when I change the channels (they do not appear in the direct TV program menu). I went into the Hughes set up menu and hid the off air channels
2. There is no bar menu when I change the channel.
I called DirecTV and they said the box may be bad which I doubt.
The latest software version I have is 1.07.
Any ideas?
Jahan
ESPN HD Horizontal Flickers
Which transponder to use when aiming?
