Need help with Dishnet | SatelliteGuys.US
409
I just switched over from DTV to Dish net.
Can someone please tell me the Azimuth and Elevation for Winnipeg.
Also will the DTV LNB work on the dishnet.
Thanks!!
Trevor
I would recommend not using a DTV dish to get Dishnetwork, it can be done, if using older equipment, but you will not be able to get all the programming a D500 can provide. As far as the settings, just goto the menu 6,1,1 and put in your zip code, it will give you the settings.
121
Any UnAdvertised Programming Plans?
