Need help with combining signals on one cable | SatelliteGuys.US
jpesc
20
I would like to combine my basic cable with the sat tv output #2 going out to my second tv. What all do I need, right now all I have is a cable from the satellite reciever going out to the tv.
You need a splitter, but in reverse.
This is how you should hook it up:
............................_____________
CABLE IN ------->|.......................|
...........................|....SPLITTER.....|----> Combined COAX (TO TV)
TV2 SAT OUT---->|____________|
Sorry for the bad diagram, but that is what it should look like.
Good Luck!
-Scott
What cable channels are active on your system? The output of TV2 has to be set for a cable channel that your cable system dosen't have a signal on.
It's also a good idea to pick a channel that has empty adjacent channels. So if 105, 106, and 107 are available, pick 106.
add a 622?
622/722 Cooling Question ???
