need help to get intelsat 14 | SatelliteGuys.US
myking
4
houston
what size dish do I need for Intelsat 14 from houston
i got a 4 footer offset dish c band lnb & conical ring help plz
6 foot minimum...preferably 8 footer
Here is what I can pick up channel wise in Minneapolis with a 6 footer (I submitted the channels for that sat to thelist)
SatelliteGuys.US - 45.0°W Intelsat 14 C
now some of those channels are very weak and wont show a picture but had enough signal to register the channels
whats c band satellite do u thing can i get whith a 4 footer offset dish i got the conical ring to
Get good reception with a 6 ft Fortec Dish including C and Ku (Internet feed). Some of the strongest transponders include 4192V (+90 sig) & 3759V (+90 sig). The weakest transponders are 3848V, 3866V (7/8 FEC), 3991V. The Puerto Mux is about +80 but because of the 7/8FEC it pixels a bit.
I get 90% quality and it's pixelating like crazy on the Coolsat, when I use the DVBWorld it pixels less but still bothersome, glad to see it's not my LNB and it's just an uplink problem.
btw 3848V, 3866V (7/8 FEC), 3991V are all very strong for me
I need opinions about Prof Revolution DVB-S2 7500 USB
Looking for information about Starchoice (Shaw Direct)
