Need Help please | SatelliteGuys.US
Need Help please
Playactionpass
6
I have a dish 500 and a 300. I need the 61.5,119,110 signals. Do I have to have 2 seperate dishes to get these signals? Will a dishpro twin dual plug into the switch or do I need 2 singles dishpro lnbs to plug into switch. I currently have 1 dishpro lnb. I tried to hook 2 legacy lnbs up to a 34 switch at first but then I read that legacy wouldn't work with DP. What do I need to do? Thanks btw I also have an 811 and 508 if this matters.
Another question
Ok I do have 2 dishes. The 300 has a single dp lnb and I am picking up 61.5. Will a dishpro twin dual (with built in switch as I understand) plug into the switch or do I need 2 singles dishpro lnbs to plug into the 34 switch from the 500.
I guess I am confused because the twin has a built in switch so you would be sending the 119 and 110 into the 34 switch on the same line. I am thinking only one signal for each input which would mean I need a 2 singles. I am new to this so please understand. Thanks for the help.
921 fan is running 24/7
Lil ???
