Need Help, please with DVDDream + Twinhan 1020A | SatelliteGuys.US
amemast
2
Hello,
I have bought Twinhan 1020a and trying to install with DVDDream. I endup taking out hardware from the computer.
Can anyone have a step by step guide on how to configure card as well as DVD Dream.
Please let me know if you have it.
After 1st try i got an error on DVD dream that says something like.
"Cannot find video rendere"
Any help would be appreciated.
Thanks,
Amemast
You need to set up your codecs to get things going. When you first run DVBDream, go to the options menu, then click on Video settings/options (going by memory). You can choose which codec to use there.
DVBDream may not be able to use the codecs you have installed on your computer now. It also can't use certain combinations of video and audio codecs. If you find yourself having problems getting a codec to work, just pop back here. :)
Thank You, I have tried different combination on codecs that are available to me. I tried that, I can't get any codec to make it work. So,if you know which codec i need that would help me to install that codec on the computer. BTW, i have Echostar 3 on the line.
Regards,
Amemast
New to FTA: Getting good signal quality but 0 signal strength
damaged dish question
