P picman New Member Original poster Aug 9, 2004 2 0 Aug 10, 2004 #1 Just purchased a Direct TV dish (3 LNB) that i want to use to pull in Dish Network satellites. Is it compatible?? Thanks
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 3,422 15,012 Mankato, MN Aug 10, 2004 #2 no Since Direct and Dish use different switches they are not compatible. If it was the old Para dish (with the LNB missing from 110), then the answer would be yes
