Need Help on connections Please... | SatelliteGuys.US
jeffwb
6
I am looking to buy a T90 dish with 3 dual output Circular KU DBS LNB's, and 3 Linear Dual output KU LNB's total of (6) mounted and I want to connect all these to 2 Pansat 3500SD receivers so either one can select any of the LNB's ie. satallites individully without interfering with the other receiver, (Seperate rooms). I believe I can connect lets say A or B out of the LNB's all A's to 2 seperate 4X1 DiseqC switches (2 unused inputs) and the two outputs from those switches into a 2X1 DiseqC for the one output to Receiver A. I then mirror the same setup for the B side of the LNB's to Receiver B.
I am not sure if I need a 22KHz switch type instead of the 2X1 DiseqC for the receivers to work the way I want.
Any Help
Jeff:confused: :confused:
Seems like a LOAD of bother for a few FTA channels that use circular polarized LNBF's?
Having trouble setting up CW-600s
Adding a Circular LNB
