Need help here in Canada! | SatelliteGuys.US
b16a
11
Hi,
I live in Quebec city, Canada and i have a lot of difficulty to get good signal.
I have a vip 222k with a dish 500 dpplus lnb (110-119) and a 36 inch dish on 129 that return in the dpplus lnb than to my receiver....
-One of the 2 input of the receiver is use.
-I can't have ore that 50% of signal on the screen but 100% on my birdog.
Question:
-Do you think if i use a eastern arc 1000.4 dish it will works better?
or western?
-Do you think my receiver is buggy?
Thanks!
I think I read through the grammar correctly enough to say that you're pretty far north, and that EA probably won't be much better. Also, you're on you're own since Dish doesn't service or be expected to provide signal to Canada.
yeah the meter on the Dish receivers is goofy...
50 to 60 is good
anything above it is great
(It isnt like DIrectv or Bell that has a 100% max meter)
I think that DISH needs to redo their meter to show 90 or 100 once again and drop the 125 scale. I Don't see why they couldn't redo it to show a true 90 or 100 on both ARCs.
Hi,
Question:
or western?
Thanks!
I do think you would be better off w/ EA since you are N of Maine. I'm almost surprised that you can even hit 129.
I agree. You can probably just re-point your dish 500 to the main EA Birds which are 61.5 and 72.7. There's no way you are going to get 77 from Quebec but unless you subscribe to Latino channels, then you won't need it.
anyway to Navigate Blockbuster Movie Pass easier ?
Stuck on "Aquiring Signal" 535 will not change Please help
