Need help for CM channel list | SatelliteGuys.US
regisma
58
Hi,
I like a lot Channel Master.
I have a Digiwave Diamond receiver and a SG2100 motor.
I have made a good channel list that will suit my needs.
The only things I do not know how to fix is the channel numbers.
I mean by that that I do not see an easy way to flush out the channels and reorder all of them by Satellite degree number. Because right now the channel list as is will ask the motor to constantly move from one satellite to another when I change from channel to channel.
I have joined my file.
thanks
Regis
Um, I hope that the channels in there you aren't using because we do not condone hacking here……since the list has plenty of DBS satellite channels in there (and there are channels missing in it so its a customized list), I have to take it as that is what it is.
Closing thread
Scan the satellites like most of us do one by one…then you can organize it exactly how you want it
36" Fortec Dish...anybody using one?
180CM is CHEAPER than 120CM??!!
