Need help choosing dish for roof | SatelliteGuys.US
dcolpitts
Atlantic Canada
Hi guys. I'm looking to order a dish from one of the site sponsors, and I'm not 100% sure exactly what I want / need. Basically, I'm picking up a HR23, and I'm not interested in internationals or locals (if they are there, fine, but if not, its not big deal) although HD is definitely a requirement. At this point in time, the HR23 will be the only receiver on the system, although I may add two more non-DVRs at a later point in time.
I was thinking that all I need is an AU9 SL3 SWM with a power supply and SWS-8 splitter (ie the AU9-SL3-SWM-B-PWS at SolidSignal.com).
Using Direct's installers is not an option due to my location.
Any comments, thoughts, or theories?
dcc
I can't picture how you would use monopoles with a pole mount. How about a picture?
Here you go!
I plan to re-route the coax around the planter.
Here you go!
Ah, I remember seeing it now. With how short the pole is, I doubt the monopoles make any difference, but they certainly don't hurt.
Insane commercial volume level for local WPTV in South Florida
Dirictv reciver
