Need help adding Hispasat feed... | SatelliteGuys.US
guajiro
5
...to an existing D* setup with D500 DPP and wing dish on 61.5 if that is possible without wiring separate.
A few months ago I was able to install a new 30" with universal LNB and got a good signal. I'm watching actually with a separate wire in one room but will like to add it to the existing Dish system and be able to watch it on master bedroom and Florida room. Is that possible without having to run new wires? :confused:
Viewsat Xtreme + 622 & 211
guajiro
FTA and Dish don't play well together. You will need to run a 2nd coax to each of the rooms that you want a TV in, as well as a new FTA receiver for each room. This assumes that you have a dual (2 feeds) LNBF on your 30" dish followed by a 5x4 switch.
Bob
Thanks for the info...
...Since my attic is too shallow, I was trying to avoid that. By now I'll stay with the present solution until I manage to run new wires accros the home. I got a tech who mixed from the TV out from the Viewsat to the Sat coax thru a diplexer, this way when I turn off the 622 I can watch whatever channel I have selected on channel 3 of main TV. :eureka
Diseqc robs signal
coolsat6000 reboots every 2sec.
