need cheap used hd dvr | SatelliteGuys.US
dkr919
4
Can someone suggest an inexpensive older hd dvr and where I can buy one for a non swm? system. My old hd dvr used the 2 bbc converters at the receiver.
Can someone suggest an hd dvr for a non swm? system. My old hd dvr used the 2 converters at the receiver. I noticed some R15's on ebay. Will those work?
I think the R-15 is SD only.
I would look for a HR24 personally if you can find one reasonably, don't forget, if your looking at ebay, chances are it's a Leased unit and needs to be returned to D*, check the numbers with D* before buying.
The HR20's is where it pretty much started and goes on up to the current recvrs.
Genie questions
