Need brown button remote for 2700 | SatelliteGuys.US
aquaman67
339
17
Tennessee
Anyone know where I can get an old brown button remote for a 2700?
I tried the blue button one, but there were no good codes for the Emerson TV.
The old brown remote, when it works, doesn't adjust the actual TV volume but has a separate volume that it adjust. A yellow bar graph comes up when you use the brown remote, the TV's volume bar graph is blue.
The blue button remote uses the TV's volume.
So...anybody got one? I tried E-Bay. I can get a receiver and a remote but I don't want another receiver....
On the blue button remote set the TV code to 222 the it will control the volume on the 2700.
It of course will not control the TV in any way then.
You are AWESOME!
Thanks a lot!
I have several old blue buttons laying around and couldn't find a brown button remote to save my life!
Again, Thanks!
Thanks for the link.
I have/had the 1.0 dedicated remote with brown buttons.
The code n0qcu gave me did the trick for my 1.5 blue button remote...
AT&T may buy echostar,what then?
Sirius Channels a la carte?
