Need Black plastic Strut Support/LNB mount for CM .75m DTN dish | SatelliteGuys.US
radio
"On the Air" in MI
3,738
908
West Central Michigan
Got my second (former) DTN .75m Channel Master dish given to me, has LNB supports, dish, all rear parts, but the black plastic LNB mount that joins the "struts" is missing. Anyone got a spare to sell? Ideas or fixes? Pole is in place, waiting for all the pieces so I can install.
Thanks as always for the help and input!
Join them by bolting in a short section of larger pipe coming straight out towards you, as if you are standing in front of the dish adjusting skew on an lnb. Just drill two holes as needed. One from side to side for the side arms, and one top to bottom for the bottom arm. Or, use an EMT elbow modified slightly as needed to match them. That's actually a bit cleaner looking, but the pipe I first suggested makes it easier to mount an lnb.
Interesting idea! (insert Young Frankenstein voice-Gene Wilder here) "it......could......WORK!"
Yeah, I have a HORRIBLE time walking through stores, because I see EVERYTHING as: "hummm, if you change that to look like THIS, or you add THAT to the other thing, you can do THIS with it, instead of what it's supposed to really be for"
lol, it can drive you crazy, because it's real hard to turn off.
Still looking...if anyone has that 2-piece LNB and strut holder for the CM .75 dish.
Would rather have an original if possible!
Sling usb for Dish 622 or 722 & OTA Modual & USB WIfi
ku lnb for bud
