I have a HR23-700 connected to a slimline 5 and starting to lose LOS to 119. Is it possible to swap out the slimeline 5 LNB with a slimline 3 LNB? If so, where can I purchase a slimline 3 LNB?
If you have no programming you want from the 119 it doesn't matter if you are losing it......you will certainly lose it if you change to a 3
Is there an advantage to getting the sl-3 swm over the sl-3? Will the sl-3 swm work with the HR23-700?
You will have guide issues with a 5 lnb and no los to 119.
Thanks to everyone! I will be getting the sl-3 LNB.
Don't forget , you'll also need the Power Inserter and possibly splitter to go with the SWM set up, if you go that route, or it won't work.
My point is, you can't just swap out the head from another unit and be done.
With a SL5-3 you can just swap and repeat the Sat Set Up, but when you go to the SWM you'll need the other equipment as well.
This is very important too. When you first swap out the LNBs from the 5 to the 3 it will appear to be working properly, but if you do not change the dish type in the setup menu to the 3 LNB, you will lose the guide data -- as stated aboveYou will need to go into the setup menu and change the lnb type from 5 to 3.
Thanks for the info, Jimbo.
I will get the sl-3 (non SWM) LNB, mainly because of the cost and the fact that I only have one DVR. One question, will the RBR detect the new LNB?
This is very important too. When you first swap out the LNBs from the 5 to the 3 it will appear to be working properly, but if you do not change the dish type in the setup menu to the 3 LNB, you will lose the guide data -- as stated above![]()
efbrune,
After you make the LNB change, Turn on the recvr and go to Menu/ Set Up/ System Set Up/ Sat and Antenna/ Repeat Sat Set Up/ dash/ then you will need to look and see which one says Slimline3 (no SWM) ... Switch Type should be Multi Switch. and Tuners : Dual.
BBC's (2) WILL be required for HD use.
Are you sure that I need the BBCs for my HR23-700?
You don't need them for any H/HR23 model, swm or not.
Thanks Chip,
efbrune, sorry, I forgot you have a 23, no you don't need BBC's.
Limited time offer
