need a lnbf for a HughesNet Dish | SatelliteGuys.US
chadg2
623
42
Maiden Rock, WI
Hi! I just picked up a slightly used HughesNet/DirectWay satellite dish with no transmitter or Lnb attached. Could I purchase just some Ku band LNBF w/feedhorn to attach to this thing to use with free to air mpeg? I'm already using my C/Ku band dish with my Traxis DBX-3500, but would like to add a dedicated Ku dish to just Galaxy 10. Also have a 4 port switch on the Traxis. Thanks for any help. Chad
nope, nope, nope! I'm sorry I don't want to use this dish in anyway with direct tv. I want to use it as a stand-alone dish for mpeg DVB from Galaxy 10R. Just wanted to know if there was some LNBF I could attach to this dish to pick up the signal when pointed at G10. Thanks, Chad
you can monkey around with it and see if you can retro something. your focal point among other things will be something you will have to keep in mind. as for any one item, that's up to you for what your working on.
I see what you mean now :) Yes Invacom sell an LNB and feedhorn that would fit on this dish (I have two myself) It would be BEST if you could use the feedhorn that comes with the dish as its designed for the shape of the dish but the Invacom Feedhorn also works well.
www.invacom.net
Pansat 2500A Support
Where am I? What do I do to fix this?
