nbc sat mux 3 & 4 audio? | SatelliteGuys.US
sometimes there is no audio on them
They are MPEG2 audio so any receiver can pick it up....if they output it from the channel ;)
Those feeds are for reporters in the field to see what is on the screen. The quality and if there is audio or not is not very important...
Why?
__________________
Some guys will tell you the proper gear ratios you will need to build an accurate clock when all you need is to know what time it is.
Enjoy memorizing satellite names because 60% of the folks in this hobby wont use location as a reference. They are very helpful,
friendly,smart but they think memorizing the names is some sort of rite of passage or mental hazing that they went through. So you
gotta go through it also.
:rolleyes:
Your G-19 Signal Report is Needed
Trouble with Tv Marti and Tvvi @30w
