I've been using my receiver with the HD set to non native so everything is in 1080i. Would I benefit greater setting native and letting the receiver change resolution for each signal?
Brian
Brian
What is the NATIVE resolution of your TV, find that out and then turn native off and try that resolution on the HR20. If you like that picture then you're done, if not try the other HD resolution (720p and 1080i are HD, 480p is ED and 480i is SD) and see if you like that better.Okay well my TV does NTSC 480i 480p 720p and 1080i, so what would be the best way to set up my HR20? Native or none etc?
From what info I can find in online reviews of it, JVC HD-52Z575, its Native is 720p
Limited time offer
