Mysterious Problem!!!!!!!!!!!!! | SatelliteGuys.US
ebehalifax
9
I bought from ebay this new Ku DUAL LNBF .4 noise figure made by LAVA to replaced my old working International dual LNb .6 noise figure. I am using DVR 522 two tuner with no switch getting signal from SAT 121 only.
I installed and i run the check swich on my receiver, it will stop after checking the first swich and I get the message that sat 121 o.k with device : DP FEED and SWICH: DP FEED. when i checked the signal strenth it was only signal on transponder 2,4,6,8,10 (only) from the 32 Transponder.
what should I do?
Not: spec for the new LNBF LAVA:
MODLE:
K-200
RF Input
Input Frequency Range:
Low Band:10.70~11.70GHz
High Band:11.70~12.75GHz
IF Output:
Output Frequency Range: Low Band:950~1950MHz
High Band:1100~2150MHz
OUTPUT CONNECTOR TYPE 75OF Female Connector
Output VSWR 2.5:1(MAX.)
Local Oscillator
L.O. Frequency: Low Band:9.75(GHz)
High Band:10.60(GHz)
L.O. Frequency Stability: (1) +/-1MHz(ROOM TEMPERATURE)
(2)+/-3 MHz(-40*C~~+60*C)
LO. Frequency Phase Noise -55dBc/Hz(@ 1KHz)
-80dBc/Hz(@ 10KHz)
-100dBc/Hz(@100KHz)
Conversion Gain
50dB(min.)
60dB(MAX.)
Gain Flatness(AcrossAny27MHzSegment) 0.4dB(typical)
Output Power@1dBGain Compression 0dBm
Noise Figure 0.4dB(typical)
Image Rejection 45dB(min.)
DC Current Consumption 220 mA (typ.)
Cross POL. Isolation 20dB(Min.)
DC Current Consumption 280mA(MAX.)
Operating Voltage (1)Vertical:11.5~14.0Vdc
(2)Horizontal:16.0~19.0Vdc
(3)HingBand:Continuous22KHz?KHz
Operating Temperature Range:
-40*C+60*C
My first thought is that it's NOT a compatible LNB.
It's voltage-switched, but being detected as DishPro - that's NOT going to work.
Also, 121 is 11.7-12.1GHz, which per your specs is "high-band" which it outputs starting at 1100MHz, but 'standard' LNBs start at 950MHz.
Finally, it looks like it needs a 22KHz tone to run as 'high-band', and E* boxes don't use that.
The only thing you might try is disconnecting it, running a Check Switch to reset the receiver to Legacy mode, and then trying again, but I really have no hope.
What is the 522 tv2 RF output?
club dish
