GEOSATpro - My MicroHD Review | SatelliteGuys.US
GEOSATpro My MicroHD Review
  • Thread starter Thread starter phantom_76
  • Start date Start date
  • Replies Replies 0
  • Views Views 1K
phantom_76
36
Ontario Canada
Well after having this unit for over 5 have to say that this little unit is a very outstanding little reciever for its size this is the first unit that iv owned that dose HD DVB-S2 and enjoying it for sure.And for the Support for the reciever WOW! have to say the best i have ever seen Thanks Brian and all you guys over there at SatelliteAV you guys go above and be on and for all the members in this form thanks for all the help you guys doing trying your best to help out with this little reciever the best you can.Well when i was looking at HD FTA Reciever i look at many different ones and let me tell you there is alot of them out there but the one thing that sold me on this microHD when it was all said and done was that it was made for North America and Supported by North Americans thats what sold me all others are out of county if and ify if you get any support at all but thats the way they go in china mass production and out the door who care if it works at the end.One thing i have been seeing lately is if you blindscan on normal all the time i thing it messes up ones and a while missing feeds but just do a detailed scan for a bit and it works again no big deal just something iv seen lately one sat thats bad for that is 83w C-Band the V side it dose not scan in PCN or the other channel all the time but a detailed scan finds it.I have found that when i had my first microHD that the HDMI port quite it did get real hot like up to 160f on the bottom of the reciever and like 140f at the HDMI port on the steal part of the cable and did notice the plastic was warped on the bottom of the unit but with this second one i have placed a old CPU fan at the bottom of it taking the heat away from the unit and now dose not go noware near that temp now 84f max much better i think no plastic has warped yet . But all and all i have to give the microHD as outstanding litte box and for the support A1 outstanding Thanks For Everything
GEOSATpro Epg timer fail
GEOSATpro Unable to transition motor to 15.0W
