My HD Picture quality | SatelliteGuys.US
PalaHeel
62
seems to be getting worse; it's not as natural as it was. I have been a Dish customer for three years and have noticed a gradual worsening of the HD picture. Regarding the channels ... all appear effected to some degree.
I have a Dish 1000 plus; two Samsung LCD, HD televisions: One is hooked to a 622 and the other to a 722. The picture quality, or lack of, is consistent between the two boxes.
Are any of you experiencing the same, or are there any suggestions you might have, in addition to calling a tech?
BTW, I have not changed my TV or box settings. Thanks.
That does not mean they can't change. Software updates have been know to alter settings. Double check you HDTV settings....ie, 1080i.
Thanks ... I should have mentioned that I did check the HD settings on both boxes.
PPV suddenly appears on Sling (remote access)
What the...???
