Multiswitch question | SatelliteGuys.US
OCHoops
Howdy all,
I have a 3 LNB dish that feeds a Tivo box (both inputs) and DirecTV's DVR (only one input).
I want to add another room (a regular receiver) to the mix and add a second line into the DirecTV DVR.
Which multiswitch will support this setup? Should I replace the dish head as well?
Thanks in advance,
OCH
I believe you will need a Zinwell (or other DirecTV authorized) 6x8 multi-switch. If you have any plans on getting HD installed, you might call customer service to see what deals they could offer you.
The Zinwell 6x8 Wide Band can work with the Standard definition, and with Hi Def too.
The Zinwell 6x8 regular work only with Standard definition.
Popping sound revisted
A big thanks
