multiswitch problem? | SatelliteGuys.US
twek
i just moved and reinstalled my satellite dish. I accidently dropped the dish while hooking it up. that said, I do have a signal on all three sattelites. However I only two of the four outputs from the dish work. The other seem to be dead. I have tried using different cables and receivers. Any suggestions would be helpfull.
Oh, it is a Phase III dish.
Welcome to SatelliteGuys! Your cheapest option is to replace the dish. I recommend Valueelectronics for a replacement source. If you don't want to go that route you could use a seperate multi-switch but it would cost quite a bit more. If you choose that route ensure you get a cascadable multi-switch. Good luck....
A replacement multiswitch wouldn't work you would need all 4 outputs working to connect another multiswitch. Replace the Dish or the three LNBs cost is about the same. :)
WARNING: Why DirecTV stinks...
Any DTV employees?
