Multisat Location????? | SatelliteGuys.US
Neykok
Waukesha County, WI
:confused:
Does anyone know of a quick trick to align a Multisat dish in WI? I have heard: start from the far left, and swing right, the first bird you hear on a satbuddy is it, then move slightly more to peak (satbuddy level approx 64).
I was a DNS tech before coming to DTV, and could lock SuperDish birds in minutes, but I'm having a bit of a problem finding a trick to speed up the lock for DTV birds. Any ideas would be greatly appreciated!!!!!!
Heck no! Type in your zip code to get the correct AZ/EL/SCEW and go buy a $10 heading compass. Lock in the SCEW and ELEVATION first. Making sure you mount is 1000% plumb and level all around! Then, using the compass, start at the approx AZIMUTH and star your process. That guessing mentioned about will leave you pulling out all your hair.
Phillips DVR second tuner not working
RCA DTC210 in less than 2 days - Thank you Value Electronics
