Multiple Hooper Record Options? | SatelliteGuys.US
BE Westerville
2
Ohio
Question
I have a 3 hopper setup, can I be at hopper "A" guide find a program and set it to record on hopper "B / C", from hopper "A" or can I only set a show from the hoppers guide to record on the hopper I am talking?
Question
If you use up the 3 tuners on your Hopper A and attempt to schedule a 4th program for recording, you'll be prompted to record that program on one of your other 2 Hoppers.
You can "force record" on another one of your Hoppers . . .
  1. Locate the program you want to record.
  2. Schedule 3 other programs for recording in that same time slot.
  3. Select the show from step 1 to record.
  4. When you're prompted, allow this program to record on one of your other Hoppers.
  5. Unschedule those 3 programs from step 2.
Reactions: Tron2012
If you have a Joey, do your recording set up on it. You can link the Joey to any Hopper you want to record on. If no Joey , you can use Dishanywhere and record to any Hopper there.
Donating DISH receiver & dish
VOD ASPECT RATIO?
