Motorola DSR web interface not working ... | SatelliteGuys.US
misterpaul
17
Hello,
I purchased a Motorola DSR box a couple of weeks ago and the web control and monitoring feature acts very strange. I am able to hit one of the pages, log in and see the menu on that particular page, but as soon as I do that the web server seems to die (IE shows a web page cannot be found message once I click on another link, whereas firefox displays a blank page). The only way to get back to the login page is to reboot the receiver.
Has anyone seen this behavior before? I've tried it on two separate receivers and they both behave the same way.
What Motorola DSR box did you get? It doesn't sound like anything a 4dtv can do. Is it a commercial receiver?
It's a DSR 6000.
I tried telneting into the box as well, but could not find the correct combination for the VxWorks OS login (although I have no idea if I would be able to control it from there). The very odd part is that I've tried it on two units, so I'm wondering if that feature is perhaps factory disabled (if that were the case I wouldn't expect to be able to log in though).
Another BUD find
4dtv technical help needed
