Motorized Dish 3 receivers | SatelliteGuys.US
kool1
76
16
I have a 33" dish and a invacom QPH-031 and need to hook all 3 receiver to the dish. I understand that I will be able to only move the dish with main receiver and will be able to watch one sat. at a time with all receiver. Can it be done and how?
Thanks Ahead of Time.
Yes, it can be done with a 4 x 4 22k DirecTV-style multiswitch. Hook up both linear (L) outputs on the Invacom to the two '22k off' inputs on the 4 x 4 switch, and both circular (C) outputs to the two '22k on' inputs on the switch. On the 4 x 4, there are four outputs. One will go to the 'LNB' port on the motor, then connect the motor 'Receiver' port to the primary receiver (the one that will control the dish). The other three outputs from the multiswitch can go to additional receivers directly. On all receivers, set circular satellites (DBS satellites) to '22k on' and the linear satellites to '22k off'.
moveing on up to c band tossing my fta lol
Dish and motor setup
