Motor and Spliter | SatelliteGuys.US
Motor and Spliter
longhalkilo
32
Well I did it this time,I screwed up my DG-280 motor.According to the manual on page 5 under "Hardware Reset by DiSEqE Motor". I disconnected the RG6 ,then press and hold both EAST/WEST buttons for 5 seconds and then reconnect RG6.The motor is still working properly ,but the LNB will show S but no Q. When I bypass the motor with a barrel connector I have S and Q on the reciever.
Now my question is can I use some sort of a high frequency power passing spliter . Between the reciecer and the motor on one side, and the other side to the LNB.Thank you in advacne for your input.
Thank you Putney.I see it is time for me to do some reading and thinking about a motor mod, and looking for parts.
Would a Perfect Vision Diplexers PVDP-2PP with DC power passing on 2 ports be a good choice.How would you connect it,LNB to 950-2400 mhz port and motor to 2-860 mhz port?
What is "The New York Network" on 79 W ?
NASA TV Moving to AMC 3 01/16/10
