MOTECK SG-2100 Trouble | SatelliteGuys.US
madmadworld
Official TV Watcher
17,106
6,969
up on the roof in SinCity
hi
my first post. been lerking for months. thanks for all the help i have found here.
i have a MOTECK SG-2100 i have tried it on 3 different receivers.
and it will not remember the sats. i get a few in (say 4) it will be ok and then as i add more it forgets the oldest ones.
i have tried the reset botton.
thanks for your time
Are you using Usals or 1.2? Also, you used the reset button on the motor??? I'm curious what angle the motor was at when you did that...
I see you also have a Stab HH100 motor, do you have these problems with this motor? I don't have an SG2100 so I'm at a loss. I find it strange that it would log up to 4 sats, especially on 3 different receivers, and then replace those when you try to log new sats into the receivers. Very strange?
Al
Al
no the stab works fine.
i start at 116 ms6 add 103 101 97 93
then go to say 97
then ask it to go to 93 and it goes to 116 :mad:
quality cable / location problem
Had to reset receiver - now getting LOTs of channels!
