More than one hdtv | SatelliteGuys.US
More than one hdtv
michaelpa
7
Is it possible to hook 2 hdtv's to a single 622 receiver or must I purchase a second 622 for the other hdtv? Any help would be appreciated.
Both tv's would be viewing the same channel if you used one 622. HD feeds are only on TV1. To have separate viewing you would need to purchase a 622 or 211.
Or you could connect tv 2 to another HD port (comp. or hdmi) on the 622 and watch the same HD channel on tv2.
fred
TV 2 has a specific meaning when discussing the 622. The solution you propose is the same one mentioned by gdarwin but in that case both TVs would be using the TV1 output.
Adding a leased reciever, fees question
wiring question
