Model 781? | SatelliteGuys.US
Model 781?
Yes it is 921's that they had left over when they upgraded HD receivers, so instead of throwing them away they re did them a bit and put a different Model number on them.
I have found that Dish remans are usually better than new. I have had to replace so far 3 501's, a 921 and an 811 nad the remans have been better than the orignal units.!!!:confused: :confused:
In most cases you're right. The only exception to that rule IMO, are the 522/625. For whatever reason, the factory reman "techs" don't seem to thoroughly check things out (harddrive, tuner outputs, etc) before sending them back out in the field.
Is Dish going to have On Demand?
Is this CSR wrong?
