model 322 | SatelliteGuys.US
model 322
phil337
8
Hello to all....I have a dn model 322.I would like to bring it down to my camp.I have a dish 500 with two single lnbs.Will the 322 work with them?I have a multi switch dp21.Do I use it?Do I use the separtor on the back of the 322?I tried hooking it up a few different ways and the 322 does not load.I have the dish pointed correct.Any help would be great.
thank you
Two cable goes straight from LNBF to the sat1/sat2 inputs, no switches required.
I'm wonder if you have everything, why you didn't test the configuration while you at home ?
thank you
If your description of equipment is accurate no it will never work. A 322 need 2 identical feeds going to each tuner. You would need dual LNBs not singles and you would need 2 DP21 switches to combine the 110 &119 signals. An alternate would be 2 Dish Pro 2 way splittersP/N120341 this requires that your single LNBs are Dish Pro.:) Dish Separators only work when combined with Dish Pro Plus LNBs or switches. Legacy LNBs require SW21 switches not DP21 switches.
The simplest solution would be to purchase a dish pro twin (or quad) LNB and run two cables directly to the 322 with NO seperator
OR
Purchase a dish pro plus twin LNB and run a single cable to your 322 receiver WITH a seperator.
Dish 500 can't tune in sat 119 and 110
How to add international channels? Special equipment needed?
