Mitsubishi HD1000 owners, PLEASE HELP !! | SatelliteGuys.US
JimMcC
580
I received my HD1000 yesterday, and I can't get keystone correction to work. When I push the "keystone" button on projector or remote, nothing happens, so now I can't correct the image(I had to angle projector up a little). What can I be doing wrong? Anyone else have this problem? Thanks.
Does that unit have a menu/setup control panel/buttons on the unit itself? Try using that to see if it works at all. If it does; maybe its a remote issue?
Hd1000
Problem resolved. The problem was I was hitting the keystone button while the small menu was on screen. Keystone obviously doesn't work with the menu up. I found this out by accident, nothing in the manual about this. I have another question though. What is the purpose of the overscan function(from 97% to 100%)? I noticed it keeps defaulting back to 97%. What do you guys have it set at? Thanks.
If I set mine to 100% sometimes there is a bit of garbage around the perimiter. I usually set it to 99%. It is a minor annoyance that it defaults to 97%
VDC.com complains to FCC against Turner
Plasma Transporting HELP?
