Mitsubishi DLP- picture fuzzy after moving | SatelliteGuys.US
Pete In Plano
211
After moving (didn't drop or bounce the TV) my HD looks almost like SD. It is fuzzy and looks out of focus. Is there focus adjustments on DLPs? I am seeing reduced quality on Directv HD and on OAR locals. Could receiver be tweaked somehow? List of gear in my signature. Thanks!!
how are you runnig your cables from the box
if you have not tryed yet run dvi cable from the tv to the box that will keep the video stream all digital. that is probably the problem the cabling not the tv dlp's can be moved all you want and never need adjusting also try setting the tv back to factory defaults hope this helps
Hill Gets DTV Converter Demo
Go video lcd tv's and olivea tv's
