A ? for TVROpro about skew on 4dtv.To set the polar skew my
setting are 30 and 70. Does this sound right,I thought the shew
had be or = 90 from H to V.
My skew is mostly 85 H -15 V across the arc On G1 it's 90 H and -10 V. Your skew seems too close together. It's possible your skew is working better at those numbers because your dish is getting sidelobes from C3 and C4. A 7.5 footer is not 2 degree compliant.
But with an LNBF it shouldn't matter.........am I right about that?![]()
Your sig says you have a LNBF therefore the skew settings should not matter as long as you have selected LNBF in the menu.
True my sig has a LNBF as my Back-up,I changed that to
the ADL RP3 C/Ku feed.
Right but my point being that once you have mechanically peaked your LNBF then the skew adjustments on your receiver do absolutely nothing.
So in Longhair's case the numbers he is seeing for skew don't matter and have nothing to do with his problem because he has a LNBF.
Limited time offer
