GEOSATpro - microHD: Problem After Editing Channel List | SatelliteGuys.US
GEOSATpro microHD: Problem After Editing Channel List
Cham
VE4GLS
2,566
1,142
Boonies
Seem to have had a problem doing the edit here. Saved the .udf file and edited the SID to zero and exported as UDF to the USB stick. Loaded the edited file into the Micro. Seemed to load ok until it re-booted, then came up with no channels. Did a reset (disconnected the 12v etc) and still no channels. Tried loading an older .udf file and I get an error "file too large". Did another reset and tried to re-scan satellites... as soon as it locks into a channel I get the "error: no space available".
I have done the database editing many times. Never had this problem before.
Will try a main software update (re-load) and see if we can get the memory working again...
-C.
Ali editor ver 20120615.
Reloaded the receiver software and it is responding again. Currently doing a multi-sat scan and has logged about 40 channels now. I'll treat my old .udf files as corrupt and start a new channel list. Might have been the USB stick went bad, static discharge, who knows! Just my luck...
Anyway I think the issue is solved. Just takes a rainy day to allow me to play and mess things up! :)
p/s:
I think it would work much better with a PLL C-band LNBF.
GEOSATpro microHD Feature Request
GEOSATpro New Receiver?
