GEOSATpro - microHD - Jerky Video on Many Transponders | SatelliteGuys.US
GEOSATpro microHD - Jerky Video on Many Transponders
ZetaMale
17,948
13,855
USA
Well at least you know the context for the way I put that.
Since you said you did not have to do manual pid entry too much you explained it well that if you only had yours hooked to ku then you would not have to do it too often I guess.
Looking at your listing you posted I saw many C-band signals from Galaxy 16 on your list so I just assumed you also had C-band but noticed what was not there.
And what was not there (on the list you posted) needed some manual pid entry to pull everything in.
Not much different than some other receivers I have tested here, but the Azbox always pulled them in with no problem.
I do like the way it plays eScapes, much nicer then some other receivers. No more jerky picture there.
I've been getting jerky pictures on a lot of transponders. SQ is >60.
Split this post off of another thread as it is off topic.
No much to go on...
What transponders and channels are stuttering?
MPEG2, MPEG4, h.264?
High symbol rate or FEC?
Have a USB attached?
Time Shift ON/OFF?
Stutter disappear if USB disconnected or swapped?
GEOSATpro About the GEOSATPRO micro HD...
GEOSATpro microHD - Not Able to Scan CW on 91w
