Megasat XTR receiver channel editor | SatelliteGuys.US
El_Viejo
97
4
Indy no place, IN
Anyone know of a channel editor for the Megasat XTR receiver? Is it a clone of Fortec Ultra or Pansat 2500? Any help appreciated. El_Viejo
if its a clone would ChannelMaster work? I know they work with the Ultra and the 2500
I've got a clone that is like the 2500 and CM works fine
Ice, I don't know yet what it is. I was hoping someone could tell me. A site harmonyfta sells it. Tnx for the response. El_Viejo
I just looked at it. It looks real close to the box Globecast uses which is a SE830
Here is a pic of the Globecast receiver
attachment.php
Some of the stuff I googled mentions using Fortec Ultra software in it (not stock firmware..these were from hacker sites). If it can be loaded in there that would be able to use ChannelMaster
It sure is a spittin' image of it alright!! Go figure since it is a 'system' programmed for 97W. It makes you wonder if one of those 'other' files would work, then maybe it will work with channel master as it stands. I will keep looking around to see what I can find. Tnx. El_Viejo
Interested in seeing what I can do...
Telefutura anywhere?
