Are you using a universal or standard LNB?
yes it will work fine.Hi,
I have a Pansat 2700A and a DSR-920 4DTV I am using with a 12' fiberglass dish. Will the Ku feed horn I use to operate the 2700A work for the DSR-410 or do I need a different kind?
I was also trying to find information on the audio channels that come in the package, and if it has hits of the 50's music as one of the audio channels.
Thank you,
rjl75
Does anyone think there would be a problem with two receivers sending power out to one antenna?
rjl75
Hi,
The KU is working with the FTA I get a lot of channels (about 30) on that satellite.
rjl75
Limited time offer
