May 15th's Xbox 360 HD DVD Audio Update | SatelliteGuys.US
LOBO2999
823
Cumming, GA
Here's what the HD DVD audio update will include on May 15th:
- Fix DD being stuck in "Night Mode" which is essentially Dynamic Range Compression leading to the sound sounding very flat
- Option to output ALL HD DVD audio as DTS 1.5Mbps (list includes DD+, TrueHD, DTS, and any other audio option offered on HD DVD discs I may have missed)
- Option to output ALL HD DVD audio as DD 640Kbps, (which it currently does, but will be fixed from the Night Mode bug), list includes DD+, TrueHD, DTS, and any other audio option offered on HD DVD discs that I may have missed.
- Option to output ALL HD DVD audio as WMAPro (768Kbps I think), (list includes DD+, TrueHD, DTS, and any other audio option offered on HD DVD discs I may have missed) for those receivers that support WMA.
- Option to enable/disable Night Mode (with the default set to off)
- Fix a number of disc incompatibilities (including DVD Essentials) as well as a number of Lip Sync issues.
Are there any G-3 rumor's yet?
$299 HD DVD player
