Master and Slave problem. | SatelliteGuys.US
vargf
47
I have two receivers 1 is the Fortec Ultra life and the other is a Pansat 500CI
with double slot to put 2 PCICM cards.
but the question how to put the Fortec Ultra Life Master and the Pansat 500CI slave. any idea.
Antena1Ku-band Motorized
|--Switch-->MasterFortecre--->Pansat500CISlave
Cband big dish
I need help.:confused: :confused: :confused: :confused: :confused:
Know I have a Master and Slave receivers but the problem is when I change
channels from C-band to Ku-band When I watching C-band channels all is good but when I change to channels on Ku-band no signal for the slave.
There is a way to get Ku-band channels on the slave?
thaks:confused: :confused: :confused: :confused:
Problems with Master and Slave receivers
:confused: :confused: :confused: :confused: :confused: :confused: :confused:
See the attached pic - it should help.
This setup is what I plan on implementing here at my place. The DVB receivers are at the mercy or whatever polarity the BUD is set to but on Ku Linear and Circular both receivers can see horizontal and vertical. If the little dish is motorized, add the motor between the receiver and the DiSEqC switch on the receiver you want controling the dish.
I got the HF splitters from Sadoun today :). I'll probabaly use whatever DiSEqC switch comes with my next FTA receiver until I can pick up a #2 DMS one.
VARGF
PLEASE keep all your posts together (and in the same area and thread)
THANKS!
Winegard, sg2100 and Invacom HELP PLEASE
The holy grail of FTA: free porn
