Map of Satellites and Transponders | SatelliteGuys.US
tigerfan33
7,241
582
Alabama
Does anyone know where I can look at what satellites Direct use for each channel and which transponder??
I know The List has a lot of Dish stuff but could not find the same for Direct.
Thanks!!
Ah, I've never seen a chart with the HD local transponders. There may not be one.
The SD locals are on the lyngsat charts posted above.
Thanks. Seems that when I go to my locals it comes up with a search before going to the channel. Going to check if it matched the transponder and sat. to see how strong that signal is.
Directv and HBO Mpeg4 8 mbps minimum
HR21 RF Internal Antenna
