Luken MUX on 137.0W | SatelliteGuys.US
Luken MUX on 137.0W
Magic Static
7,498
4,853
Montana
I was tweaking my Laser C/KU dish, and found I couldn't get a peep out of the Luken MUX. But I showed and IRD of 84 on the AI TurboS2. After a bit I discovered the SR and FEC had changed since I had last tuned those in. When did that happen? I must have missed that info on the board here. so I have the mux at
4160,H,29123 3/4 8PSK
That is the S2 mux. There use to be a DVB mux at 4080 but that has since been shut off (a month or so ago)
I know on the Manhattan I had to tweak the frequency to 4165 to lock the signal
its a glitch on the Manhattan
if you blind scan it shows 4160 H 29125 and logs channels. But to get them to show you have to change the frequency to 4165 to 4170 for signal to show up.
DSR410 Hor/Ver and LNB power problems
Pansat 9500 vs 9200
