low signal strengths on 110? | SatelliteGuys.US
matty8199
40
interesting problem i've been having ever since i had my dish installed last year - i have excellent signal levels on 101 and 119 (high-80s minimum, mostly low-to-mid 90s on all conus TPs)...but my signals on 110 are normally high-70s to low-80s, sometimes even lower. any reason for this? i dont have any trees or anything that would cause me to have a LOS issue with the middle sat...if i can get 101 and 119 i should be able to see 110 as well. if anything, there are trees that would affect 101, but they're obviously not...
even though you have good signal on 101 and 119 have you tried tweaking the skew? Are you getting bad rain fade or pixelization? If not don't worry about it!
Not getting bad rain fade or pixelation, but I assume that's because there isn't much SD programming on 110...
national bean
Can two dishes interfere?
