Low signal on Tuner 1, not Tuner 2 | SatelliteGuys.US
Hawk88
282
9
USA
I am getting low signal on tuner one for Sat 129 (have not checked the others), hanging around 28-34, tuner 2 gives 44-46. This is on 2 of the vip722's I have. I thought I might have a line of site problem, but maybe not. Any reason one tuner would get less signal??
I unplugged the switch and removed the incoming connection on port 1. I noticed that port 1 was a little loose. I tightened everything back up and reinserted the power and everything is good. Getting 44 on both tuners. I'm not sure if it was the switch needed to be "reset" or the loose connection on port 1, but Im all good.
Question about External Hard Drive
Dish 500 connection problem
