Low signal on SC | SatelliteGuys.US
Low signal on SC
Tommyboy
338
13
Is anyone getting little or no signal on channel 291 (foxHD)
I get 80% on the other channels and only get 56% on that
one down here in miami Fl.
Please check your signal for me to see if I need to play with my dish.
There is a variation of signal strength on different transponders of all satellites.
What is your signal strength on TLC HD and Superchannel HD?
Then there is nothing for you to do - except maybe install a larger dish. TLC/Superchannel/FoxW HD are all on the same transponder. So if all the other F2 channels have high strength, you are properly aligned.
Played with the dish a little and now getting 77% on HD channel 291 and the other channels getting 85% now all good here thanks
OTA tuner for Starchoice 505?
BEV 9242 Upgrade & SW44 Connections
