Lost Recordings | SatelliteGuys.US
Lost Recordings
Someone posted awhile back about losing all of the old episodes of Dancing With The Stars that had been saved:
I am not sure if they had been saved from PTAT, but it could be the same issue.
I can tell you that after the last update, dear old mom's H3 had its PTAT reset to OFF--completely with no channels active and no days active as if fresh out of the box and installed--along with a few other active features also reset to OFF. We had to manually go through and turn features back ON. Meanwhile, my H3 had no such issue after the last firmware update. My problems are the messed-up trick play and the mess with Bar Mode 4 PIP. My PTAT was still active and never turned off by the update.
Dish satellite dish removal
Undisclosed Dish Anywhere Limitation
